greetings everyone! just wanted to get a little feedback from everyone on my most recent wheel alignment. for reference, it's a '93 dx sedan, eibach sportlines, kyb gr-2's, but no camber kits (i know, i know! i'm saving up). my points of interest are the REAR specs:
front driver has -1.5 deg. camber, 2.5 deg. caster and 0.00 deg. toe
front pass. has -1.8 deg. camber, 2.4 deg. caster and 0.00 deg. toe
total front toe 0.00 deg.
steer ahead 0.00 deg.
rear driver has -0.4 deg. camber and 0.17 deg. toe
the shop said they just missed the acceptable range of toe (0.00-0.16) because they could no longer adjust for it.
rear pass. has -2.0 deg. camber and 0.06 deg. toe
i was told the camber must be addressed, but that it would help the toe on the driver side (this statement didn't quite add up to me).
total rear toe 0.23 deg.
so here's what i'm interested in your feedback in: what could be causing the lack and excess of negative camber in the rear driver and rear passenger sides, respectively? also, will fixing the camber on the passenger side help the toe on the driver side? my first guess to the second question is "no" but i may be wrong. thank you.
