I'm about to install my new springs and struts. I've youtube and read everything I could find on how to do it. Any tips?
Installing suspension
-be patientOriginally posted by Need4speed View PostAny tips?
-take breaks
-have beer readily available in cold chest full of ice
-spit alot
-wear goggles- all that shit falling on your face sucks
-use a torch for stubborn bolts, try not to break them
-use loctite on everything
-double check your triple checked work-serisouly
-dont use junk
-DONT USE JUNK
-^^^ See above^^^Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
No. You didn't read everything you could find. If you had, you would had noticed the sticky at the top of this section.
Sticky: *** Suspension Thread Index *** Look here FIRST
* Suspension InstallLast edited by JoshM; 03-09-2011, 12:38 PM.
Bro I've read that about 5 times and the rest of the tread 2 times. It seems to me that the hardest part is gonna be braking nuts and compressing the springs to get the mounting hardware off.Originally posted by JoshM View PostNo. You didn't read everything you could find. If you had, you would had noticed the sticky at the top of this section.
about to get my hands dirty!
if youve read everything then you have all the tips you need...Originally posted by Need4speed View PostBro I've read that about 5 times and the rest of the tread 2 times. It seems to me that the hardest part is gonna be braking nuts and compressing the springs to get the mounting hardware off.
My Members Ride Thread
You have to think outside the box to get IN the box!
I read that thread over and over, then printed off the first post. I did the suspension install by my self in about 3 hours. It was the first thing I worked on when I got my Accord. I knew nothing of Accords, or Hondas for that matter. If I could do it, anyone can.Originally posted by Need4speed View PostBro I've read that about 5 times and the rest of the tread 2 times. It seems to me that the hardest part is gonna be braking nuts and compressing the springs to get the mounting hardware off.
Yeah, I used the suspension thread my first time too, good info.
One note that's not in there: It is 100% safe to remove the strut nut without compressing the spring IF you use a socket wrench to remove it with a rug over the spring assembly and your foot on the rug. Socket catches the nut and rug dampens the spring rebounding. Nothing bad can happen and it's perfectly safe, I've done it alot of times.
Oil the end of the strut rod so it won't spin when trying to remove the last few threads and be done with it. The reason people say not to do this is because some idiots use open end wrenches and the nut knocks their buddy out across the shop when it flys off. Dampen and catch the nut with a deep socket and you'll be amazed how easy it is.
My Member's Ride Thread
Ive always used a floor jack to compress the springs. works perfect and works great moving other parts up and down to where you need them so you dont have to hold it up yourself.Originally posted by Need4speed View PostBro I've read that about 5 times and the rest of the tread 2 times. It seems to me that the hardest part is gonna be braking nuts and compressing the springs to get the mounting hardware off.
