Preliminary info:
Control arm bushings are perfect, ball joints (upper & lower) have no movement, tie rod ends are TIGHT, axle is a reman RAXLES.com axle (GREAT quality), caliper and rotor are verified bolted tight.
Issue: When approaching a stop with brakes moderately/lightly pressed, I'm hearing a clunking from the driver's front. It sounds like something is knocking back and forth between two walls. I had my wife shake the steering wheel while the car was on ramps with me under it and the only noise I hear seems to be coming from inside the rack??? Does anyone else's rack make a slight knock/clunk when shaking the steering wheel?
My boots on both ends are cracked and the end seals are leaking a little but I've added no more than half a pint over the last year to keep it topped off so it's a very slow leak.
My thought is that the sleeve/guide at the end of the rack is worn allowing the shaft to move back and forth a bit.....but not bad enough to cause a huge leak????
I found THIS GUY in my state who seems to sell very affordable, quality rebuilt units and I'll probably buy from him instead of the hit-or-miss racks from the various parts stores.
