question about "cheapest way to lower CB7"
    i was looking at the thread to about the cheapest but safest way to lower my cb7...will it work with the CB9 ? and how low will it sit? and if im going run wide wheels do i have to do more to it? or it'll sit just right
    there isnt one. get some nice shocks and springs that is only way.
    (129)Transactions and counting
      Yes, you can. The only reason I didn't go with springs/struts was because I was worried about the rear sagging in the long run. I haul around a bunch of shit in the back at any given time, and it made my sedan sag quite a bit... I figured with the added weight of the wagon it'd make it sag worse.
      There isn't a thread titled "Cheapest suspension setup for lowering your car"? Hmmm, weird.
      http://www.cb7tuner.com/vbb/showthread.php?t=177130
        i was thinking about going with adjustable coil overs, will it work with the shocks posted in that thread?
          No. If you want coilover sleeves, get Ground Control and Koni Yellows.
          If you're wanting full bodied coilovers, several can be had for pretty cheap.
          Function and Form Type I (which I have) is about $600.
          Tein Basics and Megan EZs are around $700.
          And so on.
            And so on.
            so if i wanna slam it what else do i have to get? do i need any extra parts? or these will be good enough?
              This was about half way down on the F2 Type Is:
              The car wouldn't be drivable if the coilovers were all the way down. So if all you're wanting to do is slam your car, these would be good.
                don't forget about getting a quality camber kit....
                and an alignment.
                92ex CB7<-SOLD 93ex CB9shiftingshift73C10
                  how much would the set up be estimating, forcoilovers and shocks. .to slam it but not too slammed. .
                  damn im so confused about this suspension shit lol
                    have you read this?:
                    http://www.cb7tuner.com/vbb/showthread.php?t=470
