I have seen no information about this stickied anywhere, or found any record of this knowledge on this site. If I am repeating what another member has said, I apologize, but I found all of this information through my own personal research and decided to share it with all of you!
There is a CHEAPER and EASIER way to do Rotor over hub conversions.
YES YOU CAN KEEP FOUR LUG IF YOU WANT TO (I did)
The knuckles from a 1998-2002 Honda Accord fit our cars perfectly. In fact, I'd say they are just about the exact same. Only difference is that bearings and hubs are press in rather than bolt in. These cars came as 4 lug cars as well, which means not only will you not need to find an extremely rare junkyard Acura, you also won't have to pay nearly 300 dollars for hubs straight from Honda like I almost did. I just went to the yard, and paid 50 bucks per knuckle, and bam. That's all she wrote.
I also decided to replace the bearings, balljoints, and hubs while I was in there too.
Everything fit a treat, and this allowed me to run the RL calipers like I wanted to.
I took pictures before the rotors went on, but unfortunately my phone corrupted them.
You can see that the knuckle design is virtually identical. Axles fit the hubs fine, too.
And yes, I realize that the brake lines are routed wrong there, that has been fixed.
Hope this helps someone.
