anyone know how you can tell if the inner tie rods are shot?
As you might have followed along on my other thread, I continue and continue to have an annoying vibration from my car.
EVERYTHING has been replaced but the drivers side wheel bearing now. But, I still have this problem which makes me think something in the steering is still not correct.
When i get into my car after work, I back out of my parking spot, and back up to the left a little.. without much steering. Then when I start to accelerate, or just turn the wheel to the left, I will get a slight "pop". It wont do it every time, but most noticably when it is my first time steering it.
I still have a vibration above 50mph most of the time. Since the tie rods are brand spankin new, and both of the lower ball joints, the only thing I can think of is internally on the rack or maybe the axle is binding up or something.
Another way I can get a very slight "pop" is if I dont have the keys in the car, and I lock the steering wheel. When the tires are off the ground, it will turn easily and then stop, but i can keep turning just a TINY TINY bit which will give a little pop. The movement is coming from somewhere other than the steering column, because I can hold the bottom of the steering column where it goes through the floorboard, and it will turn just fine.
Any guesses? Its getting REALLY old.
(I took my power steering off due to the fact that it was easier to turn to one side then it was the other)
but other than that the car turns fine!
