i just lowered my car more and now it's way to bouncy. I think the kid at my job lowered it from the turn thing under the spring. i guess he mess up my spring rate. i know sure... how can i fix this
D2 Coilovers
damn cj lol. well like i showed you before. the only way to lower them more is to just take out the damper fork in the front then adjust.
for the rear you would have to take the lower bolt and nut then adjust..
what your coworker did is just make the little spring move around so its going to feel really shitty
and now you need to re-preload the springs too.The CB9 has been reborn into a CB3
Members Ride - see my cb3 here - DOHC powah
Check out my JDM F22B swap
Watch my CB7 video
Try raising your suspension up as high as you can.
Then check if the bounciness is still there.
You might be just riding your bump stops.
Also, you have to let the springs break-in.
Depending on your regular commute, it might take a couple of weeks.
DEVOTE
FS: Lokuputha's Stuff
Originally posted by 93Lxi fixed it.. i didn't want to wait anymore so i just put the car on the lift and started twistin and turning.. i saw how it worked and what we did wrong and was like damn this is mad easy
What was it that you did wrong?
How did u fix it?DEVOTE
