offset?
    offset?
    What offset are people running on their wheels here?
    I have my eye on 2 sets of wheels and that maybe the determing factor....
    Thanks in advance....
    cb7 less once again....
    What size are the rims and what is the width? I know 16x7 goes good with an offset of 40, but I guess it depends. If you want to be poking you can go a bit lower something like +35. Look at the member's ride threads and look for people who have listed their wheel offsets. I know timmyOtool does.
    1992 Honda Accord Coupe LX
      mine are motegi 18's with a 45 offset.. the higher the number the closer in they are,, the lower the number the further they stick out,, like mine are 7.5 wide so i needed them in further than the stock size.. make since?
      "Self Renewed"
        i'm running 16x7 +32 in front and 16x8 +32 in rear, pretty much have to run a bit of camber to clear the rear fenders with 205/50/16 tires
        Retired 1990 Accord LX Coupe
        Project 240SX
          Mine is +42 I believe. I think our stock wheels run about a +38 offset, but someone correct me if I'm wrong. I think for the best handling of the vehicle, it is best to go with an offset as close to stock as possible.
          My swap thread
          Main relay proplems?--DIY
            yes and no to the handling. because like my rims are alot wider than stock,, so you have to suck them in further so the edge doesn't rubb the fenders,, it still further out than stock but it's also closer in than stock because of the width,, thus making for more tire to road traction giving it better handling.
            "Self Renewed"
              no i think there a +50 if you put the stocks back on after having like a +40 you can see a big diffrence
