so on the 5 lug conversion on the front do i get the prelude calipers? also does anyone know about the lower ball joint on the knuckles? i read that you could try to swap the accord and prelude ball joint or grind out the accord lower arm hole (which isnt a good idea)...could i run a prelude lower control arm without having to get a prelude crossmember? i am really wanting to do this but i dont know what all parts i need for the front and rear...what about odyssey and oasis parts? which is easier? i read the write up but it didnt seem to clear...just wanting to know a little more...also what is the what is the biggest or deepest offset somebody can run on an accord?
5 lug conversion help
This topic is closed.
http://www.cb7tuner.com/vbb/showthre...ght=conversion
^1. front 5lug
^2. rear 5lug
^3. all prelude way
re-read all three. all should be covered.
what if i have rear drums still? how do i do the 5 lug conversion from drum to 5 lug disc? also are wheels bearings or ball joints swappable between accord and odyssey front knuckles?Last edited by accord93racer; 09-26-2006, 05:39 PM.
i think you have to get discs u might as well do them, unless you find the hub and drums for a five lugOriginally posted by accord93racerwhat if i have rear drums still? how do i do the 5 lug conversion from drum to 5 lug disc? also are wheels bearings or ball joints swappable between accord and odyssey front knuckles?
http://www.cb7tuner.com/vbb/showthre...isc+conversionOriginally posted by accord93racerwhat if i have rear drums still? how do i do the 5 lug conversion from drum to 5 lug disc? also are wheels bearings or ball joints swappable between accord and odyssey front knuckles?
seems to me that you didnt do a lick of research.
what bearings and ball joints exactly?
http://www.hondaautomotiveparts.com/
^compare the part numbers.
no i did research i just couldnt find what i was looking for...so i have to do a 4 lug rear disc conversion and then a 5 lug conversion? i cant just go from rear drums to 5 lug rear disc...i also did research and found that the lower ball joints are the same number but i didnt know if they would work...i was just wondering if anyone else had done this...
if you did, you would know that you need to convert to the rear disc for the trailing arms, then go from there to your 5lug conversion.Originally posted by accord93racerno i did research i just couldnt find what i was looking for...so i have to do a 4 lug rear disc conversion and then a 5 lug conversion? i cant just go from rear drums to 5 lug rear disc...i also did research and found that the lower ball joints are the same number but i didnt know if they would work...i was just wondering if anyone else had done this...
