i just bought 15mm eibach spacers for my sawblades... can you guys post pics if your running spacers, what rims you have, and the size of the spacers. thanks.
whose running spacers
Did buy some extended wheels studs too?
CLICK ON SIG FOR MEMBERS RIDE
"2SIIC"
Authentic Jerseys for sale
http://www.cb7tuner.com/vbb/showthread.php?t=188314
i got the ones that have the extended studs already on them so i dont have to remove the stock studs. they were more expensive but easier to do and since im working full time + now i dont really have the time to play around with my car as much as i used too.Originally posted by Davids92Accord View PostDid buy some extended wheels studs too?
alright well heres what the guy told me. i basically had three options. keep in mind this is my shop where i take my car to get worked on for stuff that i cant really do myself nor have the time too. i like them a lot and they have been in honda tuning magazine a couple times. he said i can do h and r which would give me a couple different sizes but for all of them id need to buy the studs separate and remove a bunch of stuff to take the old ones out. i don't know much about our braking and suspension so i didn't bother. then he said that eibach made easy bolt up ones for our pattern in 5mm and 15mm. then there are of course the cheap ebay china brands which were probably crap... if you check ebay for our bolt pattern they are around 80 bucks for a set of 2 and there the kind that you have to remove the studs on. the eibach ones were 150 for a set but since ive done business there before he gave me 30 dollars off so i paid 270 for all four. i decided to go with 15mm all around. 15mm should make it flush maybe a lil poking out but 5mm do nothing really. so i went with the 2 sets of 15's for the eibachs. the h and r's were cheaper but like i said i didn't wanna mess around with taking out the studs. it might be easy it might not be but from what i read on some other forums the fronts can be challenging. so yeah around 270 all and al and ill defiantly be sitting more flush and fill up more of the wheel well.
honestly though this is an experiment. kinda an expensive one for me but my 2 friends both have gti's. they both have coilovers and the one has spacers. makes so much of a difference. so i figured id try them out on a cb to see if it looks the same. i must add that i love the look of slammed spaced out gti's, well see how the cb takes to it.
Those suck.Originally posted by Flatline View Post25mm bolt ons...
Get wheel adapters that are hubcentric. I got a full set for my z over a year ago. They are made by ichiba, expensive but they are hubcentric and good qualityWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
sorry I ride with it on my 300zx. Took many twisties and corners and they havent fallen off =).What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
go get some washers and measure 15mm, possibly washers that are 5mm in thickness or something. Put them on the lugs, and then scoot your tire on, it probably wont hold, but if you lower your car so that it matches the tire, you can observe how close or how far that you would want it.
Then to determine how much of a spacer you want, just calculate how much spacers you used.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
hahaha well i already ordered the 15's just cause i think 25 maybe too much. my friend has 20's on his gti and it sits like perfect and 10's on his front and it still looks good so i think 15's should be good. accords for the most part have the same side fenders. for gti's the fender is more poked out in the rear so i think thats why he went bigger.
there is a lot to consider when thinking of spacers.
OEM fitment
Fender relationship to wheel hub
Tire sizes (especially width)
how low the car is.
Camber (if you decide to go flush)
Susupension design (if you decide to go flush)
Its hard to guess, its best to get down and do some measurments yourself.
2 people with 2 differnt cars, in your case vw and a honda, can have 2 differnt sized tires and wont fit correctly with your spacer size.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
any pics of these installed yet im curious to see how reliable these are
"2SIIC"
