tire psi?
    tire psi?
    what psi do you run in your low profile tires?
    38
    any lower
    2.63%
    1
    30-31 psi
    5.26%
    2
    32-33 psi
    31.58%
    12
    34-35 psi
    26.32%
    10
    36-37 psi
    10.53%
    4
    38-39 psi
    7.89%
    3
    40-41 psi
    13.16%
    5
    any higher
    2.63%
    1
    40 psi...
    sometimes 35... nothing more or less then those two pressures
      same here..i try to keep them between 39 and 40 psi
        I bet you guys have some traction problems
        Originally posted by DoctorCipher
        ...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
          no not really... only in the rain.. my tractions fine
            32 psi. anything more will make the ride alot more uncomfortable and cause some traction problems, especially putting in close to 40psi.
            5.6L V8 32V DOHC
            JDM HERITAGE - US BUILT
              i use to run 32. then when i got my alignment they bumped it up to 35. the car rides alot better. but when i do autocross its goes up to at least 44.
                i run my low pros at 44psi
                (\__/)
                (O.o )
                (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
                  i have the bfgoodrich g force sports and run them between 38-40 psi daily driving not racing. they grip like crazy. the ride is better altho i still have stock struts and springs
                    thats the max rated psi, you know, right?
                      hmm..weird, cuz you and i have the same wheel size and tires. i had them at like 35, but the tires weren't wearing in the middle, like at all. so i bumped the psi up. an di dont have traction problems at all. i have a slipping clutch and i cant even spin my tires. maybe barely if i dump it and turn. haha.
                      ona different note, do you suppose that the part of my wheels between the tire beads is flatter and so the volume is decreased causing the reading to be different? idk about that kinda pressure stuff.
                        44! its my tires recomended PSI
                        btw my tires are 45mm tall
                        93 Accord LX Sedan (sold)
                          Hmm didnt see the low pro in there but i got 195/65/15 dare i say...i think thats right...and i run 32-35 cuz thats what the specs call for and it rides smooth!
                            how does PSI affect traction?
                            im thinking of running around 35 psi on my 205 55 15's, looking for more input
                              i used to work for discount tire and we always set low pro tires 17 in and above to about 35 psi. if they are stock wheels and tires, then just go by what the sticker says on the door or the door pillar. Accords should be 32psi. Also do NOT exceed the max psi on the tire, that can cause a blowout and/or tread separations at high speed. But running 32-35 psi on our cars is usually whats recommended or suitable.
