HELP can not fix this idle problem clip inside
I've never seen this before either. I could see this possibly happening when your A/C compressor clutch engages/disengages. The IAC may be overly responding to the clutch engaging....try swapping out with another IAC if you can find a used one somewhere.My Member's Ride Thread
