Hello! Problem here..
Swapped from f22a to h22a!
Months later i swapped the automatic tranny to manuell tranny. Got told that the chipped ECU would work with manuell, and it does.
The engine will not start after swapping, it does not even give a try.. Like it has no power..But thats not the fault.
Seems like the ECU searches for the "PARK" (P) position on the old gearshifter.
Can someone here at CBtuner tell me where to find those cables so the ECU knows it is in PARK ? Or what it can be?
Thank you very much!
