i picked up a 97-01 prelude front complete spindels and the rear arms with the e brake cables. oh i got the rims and tires too. now will it be a easy swap? i've read that i need the drivers shaft cause it's longer and type-r rear rotors? if im replacing the whole thing i'm guessing its a direct bolt on am i correct? thanks for any input....
5-lug conversion
Originally posted by maney77 View Posti picked up a 97-01 prelude front complete spindels and the rear arms with the e brake cables. oh i got the rims and tires too. now will it be a easy swap? i've read that i need the drivers shaft cause it's longer and type-r rear rotors? if im replacing the whole thing i'm guessing its a direct bolt on am i correct? thanks for any input....There are no black and white suspension answers!!!!!!!!!!!
Originally posted by cb7dazz View Postidk why people like using prelude parts for. its way too much hassle imo
i have everything odyssey up front, install took me 45 minutes for both sides, smooth as butter
in the rear all you have to use is prelude hubs, and type r rotors which is again super easy to install
is this how you did ur wagon? any info would be great since i am shopping for the parts for 5 lug! thanks in advance" The value of life can be measured by how many times your soul has been deeply stirred " - Soichiro Honda
Originally posted by Accrdwgnguy View PostThere are good write ups in the DIY section on 5-luggin.
Oddy stuff is a bolt up in front because 1st gen oddys use the exact same front knuckles as the 90-97 Accord." The value of life can be measured by how many times your soul has been deeply stirred " - Soichiro Honda
Originally posted by AlmightyAccord View Postive been hearing more and more about just needing the Prelude Hubs and Type-Rotors... since when? is there a write up on this somewhere?
i just noticed you are from jersey, i would be more than willing to give you a hand and show you how its done
front
95-98 front odyssey knuckles complete from ball joint to ball joint
rear
97-01 prelude rear hubs (non sh model)
97-01 integra type r rear rotors
that is assuming you already have rear disc brakes on your cb. if not then you will have to do a rear disc swap firstLast edited by cb7dazz; 02-03-2010, 01:55 PM.
so not even if i use the rear break assembly. as far as the whole setup that bolts up to the trailing arm.. its just like a waste of money buying all that rear break setup just for the hub and not able to use the rotor or caliper... i've been looking at diagrams of the rear arms and they look like they fit but i'll be doing this weekend so if it fits i'll post it..
