I've got a 93' CB7 and am about to swap my F22a1 for the JDM H22a. I'm following the swap guide by converting the auto tensioner, replacing the oil pump housing (broke during conversion), timming/balance belt, and seals. I'm about to finish the oil pump install and am waiting an o-ring the pump didn't come wth.
While prepping the oil pan for reinstall, I found that getting the old gasket off is far from easy. The block side is perfect, but the pan side is fairly melted it seems. My main tool has been razor blades and an actual gasket remove tool, but it's taking awhile and is very tedious. I'm sure it will take forever regardless, but has anyone tried gasket remover or heating the gasket up with a torch? I'm thinking that if I can get it warm but not hot, it will make it a lot easier to get it off. Thoughts?
Just make sure you torque the nuts & bolts to spec, so you don't squish it out which will leak.
