Hey Guys,
I bought an OBD1 JDM H22 from HMO and during the timing belt tensioner conversion, broke a piece of the oil pump housing off. Unfortunately, I had to purchase a complete oil pump housing.
I'm running into a BIG problem during the pump install. As you can see in the picture, the rear balance shaft moulding in the housing is slightly thicker than the JDM housing. This is preventing me from getting the thrust washer and balance shaft gear back on. What's interesting is that the thrust washer is 1/8 of an inch thick, and the new USDM pump moulding is almost exactly 1/8 inches too thick; almost as if the new pump doesnt require the thrust washer at all. Also, in the pic you'll notice that the old housing has a balance shaft bearing when the new one does not. What really concerns me is that if I leave the washer off, will it cause any damage to my engine? My Helms manual shows the washer but doesn't mention a scenario of it not being necessary.
I'm in desperate need of some help!
