So i got my swap to crank but wont start, the coil doesnt give spark but it worked perfectly fine on my f series , any help?
Engine cranks but wont start
If your coil doesnt give spark NOW, that's kind of your problem. Crank but no start means a fuel or spark issue, and you say yourself you're not getting spark. Check all the wiring related to it. And how does your harness ground stretch all the way to the firewall but not reach the t-stat housing from whence it came?
How the hell is that happening? You bolt the ground strap to either the bottom stud where the t stat housing bolts to the intake, or one of the bolts holding the t stat housing together. There should be NO way that ground strap reaches that far.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
