OK, heres the deal. I did a swap on my cb7 and put a f23a in it. The thing is I cant control the fast idle on it and besides the ports are like a virgin, tight and small but the f22a is dirty slut wide open. I really want to put back the f22a manifold and I also have the A6 manifold. Problem is one of the antifreeze or coolant ports dont match. Has anyone ever had a port matchup problem that they actaully solved. I was thinking if I can move the hole over on the intake mani to match the head, that it would work. If anyone has done this or know where I can get this done please just let me know. Thanx
Intake mani question f22a f23a
Why dont you just spend the money and port match your IM with the F23 one that is?
make sure you dont have any vaccum leaks. using your finger, see if you can plug the holes that are in the throttle body opening. if your idle is still fast, you have a leak somewhere. keep the manfold you have it should work out ok.
you can also remotely locate the iavc like i had to do to fix the idle issue.
how high is your car reving to?
It revs pretty high, My tach doesnt work to well but it sounds like its bouncing up and down between 2300 and and 2700 even when warmed up. Then when I take my hand and block off the air pipe, it drops all the way down to a steady 1000 rpm or lower where it should be. Means that the valve is letting in too much air and I cant control it with the F23 TB because it has no screw. Also if I drive the car with this high up and down idle, it bogs among acceleration and jerks violently.
well, i guess it could be your fiv also. the reason im guessing its not is because when my fiv went bad, the car would idle say between 1000 and 2500 extremely fast. and then when the iacv went bad, it would idle all the way to 4k, slower, and the car bogged and jerked when i drove. it didnt do that when the fiv was messed up.
here are some pics of the iacv relocation
one side get plugged to the intake manifold
the other to the intake side
or just make sure you have the o-rings on correctly. but as i recall the iacv on the f23 manifold is weird and you cant connect it to the odb1 plug. maybe that was just in my case. i was using the intake from a 98 f23. oh ya and also you have to block the holes behind the tbLast edited by RENR; 06-06-2006, 11:53 PM.
Originally posted by RENRwell, i guess it could be your fiv also. the reason im guessing its not is because when my fiv went bad, the car would idle say between 1000 and 2500 extremely fast. and then when the iacv went bad, it would idle all the way to 4k, slower, and the car bogged and jerked when i drove. it didnt do that when the fiv was messed up.
the map would throw a code. iacv can act fucked up and no code would be present.
if you look in the throttle body opening, theres two holes in there, you can almost see it in the picture
so, if theres no leak on the iacv,, then you probably have a messed up gasket.....try pluging the hole with your finger and see if the idle evens out. if it does, then you have a leak, or bad iacv. if not, its the fiv issue
OK, You meant the holes inside of the TB that feeds the TP and IACV. I thought you meant the back of the TB, anyway, Im checking my clutch assembly as of now so I can't run the car but when the tranny is back up I will check that. But if I cover the idle hole witgh gum or something, the only difference would be that it wont cold idle correct? Thanx for your help man
your throttle plate may not be closing all the way... if you dont hear it snap shut when you turn the rotor by hand and let it go, adjust the cable looser a bit..
Originally posted by CBAccordA4OK, You meant the holes inside of the TB that feeds the TP and IACV. I thought you meant the back of the TB, anyway, Im checking my clutch assembly as of now so I can't run the car but when the tranny is back up I will check that. But if I cover the idle hole witgh gum or something, the only difference would be that it wont cold idle correct? Thanx for your help man
