just swapped my 90 ex 4dr auto to a 5spd and to a f22b dohc. No problems much, the car feels great. There is a CEL and its the TPS code, except im not sure it has one (dumb question) and where to get it or how much they run. Another question is the gauge clutser. I put in one from a 90 5spd and the numbers light up at nite, but the actual gauges don't. Anyone know why? Thanks for the help guys
Just swapped....two problems!
yes it has a TPS sensor. you can go the the junkyard and snag the throttle body off a H23/F22 and use that throttle body or tps sensor(see link below about removing tps sensors). cant get them anywhere else unless you wanna buy the entire throttle body from honda for like 450-700. OR you can recalibrate/reset the current TPS sensor....
http://www.cb7tuner.com/vbb/showthre...ght=TPS+sensor
good luck!!!
SeanF22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
i dont see why not! its a prefectly good TPS sensor right?Originally posted by vmchurchWooHoo, i have my old f22a4 sitting in my apt, anyway i can use that TPS??F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
yes.F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
so you switched the ones in the very top of the cluster? and maybe check allyour connections....Originally posted by vmchurchim so happy i could cry, thanks for the help! Any reason my gauges won't completely light up? I really don't think its a bulb, i switched them all with the ones from the auto that i knew were working.
i would swap the entire throttle body to be honest... its a lot easier... but if you really want to remove the TPS then you need a file or a dremel to make a spot for the screwdriver...Originally posted by vmchurchAnyone have a clue as to how to get the TPS off the IM? THeres two screws but they aren't phillips or flat or 6-point so im kinda lost.
It has to be set also, if the adjustment is too far out the sensor wont read the actual throttle position, therefore throw a CEL.
The write up explains how to do this, or you could take it to honda
My 5.7 LS1 Holden Ute
Yep screw it back in, but keep an eye on the voltage when you do, they are very sensitive and sometimes the reading will change from accidently moving it as you screw it inOriginally posted by vmchurchYea i just read that in the DIY section. All you do is slit the red wire, ground it and rotate the TPS to get ~.45V? What happens when you do get it, im assuming screw the dam thing back in. I rotated it the way it would fit to the TB.
