I bought a h22 high pressure power steering line from the dealer the other day (170 bucks!!). I went to put it on and the receptacle on the power steering pump was waaay larger than the fitting on the power steering hose.
Anyway, I was wondering if you guys had any problem with the JDM h22a power steering pump not working with the USDM h22a1 power steering hose.
This is the fitting I was referring to:
The receptacle on the power steering pump is 5-10 mm larger in diameter than the fitting on the hose. I'm almost positive the hose is correct; it was a dealer part and I double checked the part number. I'm thinking my next move would be to get a h22a1 power steering pump off eBay. Either that or just run the f22 p/s system.
) its for a 5th gen accord. P0A like the 94-97 p/s pumps. (just checked the parts catalog)
