Ok did the JDM H22 w/Manual Trans Swap and P13 ECU , Im getting a code 6 wich Means Coolant Temp Sensor , Ive checked the wiring , Completelly replaces all the sensors , I used the F22 Water Neck so there is 3 sensors now , all my sensors worked on the F motor so I also used those and im getting a code 6 , took out the P13 ecu and stuck in my f22 ECU and it threw same code ... what could this be , I cant understand it im using the F wiring harness and all but right now its got no vtec ofcourse because the temp sensor issue , Ive reset the ecu a bunch and rechecked all the wires , ohm tested the sensors everthing seems to be right but my comp is tellin me there is a bad coolant sensore ... anyone ever come across this ?? Please Help if you can
Thanks
-Noxidea- Sean
AIM= stng277
Yahoo= noxidea2000
Please instant message me if u have info ASAP .......
