Solid CEL Help!!
    Solid CEL Help!!
    ok this is a new post my other post was when i had a solid cel but it didnt start....
    ok so i got it running now and i got a solid cel still no idea what its for. My car spudders uptil like 4500 and wont rev any higher like its in limp mode. Only thing that i do know thats not on my car right now is a o2 sensor. anyidea what the problem is with my car?
    thanks
    josh
    Project EX Coupe Coming Soon...
    ..::Built not Bought::..
    so put on the 02 sensor
      Did you jump the CEL connector? It will only give you a flashing code if you have properly connected one wire to the other on the connector (under the dash, passenger side)
        damn.... you got one hell of a problem bro... but join the club... i guess MOSt of us CB7 owners have to put up with the stupid CELS... ( DumB ShiEt, i HATE THEM)
        Tommy Gun.... Gunning It all dA waY...
          x2...
          MY YOUTUBE Channel Plz Sub for the Support thanks
          ^^^ Click for the Link ^^^
            Start with hooking up an O2 sensor and go from there!
            If you do have the connector wires jumped a solid CEL means that there are no DTCodes stored on the ECU. If you do not have the connector jumped and you are getting a solid CEL. That would usually be a problem with your ECU and would put you into limp mode. In this case it could be that you do not have an O2 sensor. It is a major sensor in the PGM-FI System. Can't be 100% sure until you actually hook one up and reset the ECU.
            One other question, Is your ECU chipped or stock?
            MR Thread
            GhostAccord 2.4L Blog
            by Chappy, on Flickr
              Wow, just wow. I can't believe there is a thread created on this.
