....whats everyone thoughts about them that have had it done or know someone that did.
cam regrinds...
Regrinds are good, cheap power, esp if they're mated with good supporting mods. Deltacams will do well, and fortunately sohc regrinds are cheap.
I got a deal from delta for my h22 cams, but it still ran me over 300 bucks. In retrospect, I wish I had gone with bisi-cams and done it right, from the start.
But if you're looking for cheap power, have at it.
BTW, there have been a LOT of threads on this. Search it up, you'll find a lot of helpful info.
go with a bisimoto cam. Their regrinds have the research and development for our engine (f22a). bisi meticulously created his regrinds the right way. Deltas are good but really just run of the mill generic grinds.
member ride thread
DIVULGE MOTORSPORTS
It's for an H23, that will be an everyday driver, doesn't have to be the smoothest idle either. Just want something to step it up for n/a now but something that will work for f/i too maybe down the road sometime. So I was thinking 262 or 272. I heard from others that haven't had regrinds that the tips of the lobes fall off WTF???Honda-mans best friend!
who said it was a dog?
PINOY PRIDE
OHIO CB7's
Assuming you know what you want......Originally posted by whitecoupe91....whats everyone thoughts about them that have had it done or know someone that did.
Just go with a known grinder.
There are many high tech coatings available so you may want to ask about that. Inspect them/it visually before installation and if anything looks funny have it checked by a experienced builder.
Tips of lobes don't "fall off" Incorrect geometry of valve train (interference) will cause premature wear/failure. Follow manufacture recommendations for installation and correct geometry. This may involve spring/retainer kit and or machining.Take that freek show to the park, maybe the squirrels will care.
Originally posted by whitecoupe91I like how it sounds, thanks Pirate! Is that a sohc? Would a dohc sound like that? Would I get both cams reground to a 272 lift or is the exhaust lobes shorter, sorry for a newb question lol!!
272 has nothing to do with lift. the number denotes the duration of the cam.
member ride thread
DIVULGE MOTORSPORTS
you can add lift with a regrind. its dont by grinding down the small side of the cam causing the rocker arm to sit lower on the cam lobe and thus raising more when it hits the peak of the lobe.Originally posted by F22HBPretty sure you can't add lift (atleast much) without adding material to the cam (like with welded cams or completly aftermarket). Regrinds only add duration.
member ride thread
DIVULGE MOTORSPORTS
