Hey guys. I'm getting a hissing noise from the car when its on. It seems to be coming from the brake booster area, but I can't pin point it and 4 technicians at my job can't find it. When I turn the car off I can hear it for about 5 seconds then it goes away. Any idea as to what that could be and how do a go about resolving the issue? Any input will be greatly appreciated, thanks. Later
Hissing noise......I'm scared. lol
I did check the lines but could not find anything. The car runs the same, and there are no oddities, nor is the idle any different.
Thats what one of the Techs said that it may be. But I don't understand what you mean by do I have power brakes after I turn the car off. Do you mean if I turn it off and press the brake pedal is it hard?Originally posted by customchord View PostSounds like the Brake Booster is leaking. How long after you turn the car of do you have power brakes.GangGreenGang 330kmiles Strong
Its kinda hard to explain. My civic had a brake booster that leaked and if you turned the engine off when driving the brake pedal would get hard in about a second and it wouldn't want to stop.Originally posted by GangGreenGang View PostBut I don't understand what you mean by do I have power brakes after I turn the car off. Do you mean if I turn it off and press the brake pedal is it hard?-1991 Honda Accord LX H22a-
Wow.....doesn't sound very safe dude...lol. I guess I could try that and let you know. And if that does happen.....then what?Originally posted by customchord View PostIts kinda hard to explain. My civic had a brake booster that leaked and if you turned the engine off when driving the brake pedal would get hard in about a second and it wouldn't want to stop.GangGreenGang 330kmiles Strong
Nah, its not the intake. This just started happening about 2days ago. When I checked it and had the techs double check 9it they all agreed that it was around the brake booster area. They didn't pin point it to being the brake booster, but maybe a line in the area, though none of them could find it.Originally posted by C91BLX7 View PostSure its not the noise that you get with an intake when you shut off the engine?
Just take the line that comes off of the booster and plug it and see if it happensGangGreenGang 330kmiles Strong
I checked the brake booster, and low and behold thats exactly what it was. My brakes are fine, the pedal does not get really stiff or anything like that so are there any risks I should be aware of because I can't afford to replace it right now, but I have to get around. Anyway...thanks for the help guys.GangGreenGang 330kmiles Strong
