Hey everyone, I feel really stupid. I bottomed out earlier, twice, while doing about 30mph. I just moved to a new town, so I'm not familiar with the roads. Apparently, even though I'm in the desert, there are drainage ditches on a long straight stretch of road, which I didn't notice until I was right at them (in my defense, they weren't marked very clearly IIRC). I bottomed out both times, with a nice loud thud. I'm not leaking any more fluids than usual, so I don't think I damaged anything somehow. Is there anything I should look for, in terms of possible damage, that I may have missed? Thanks everybody.
Bottomed out, slightly concerned
Originally posted by JYardBandit View Postclassic honda
but to answer your question just get under and make sure there arent any crack or whatever on the oil pan and you should be fine.
My Members Ride Thread
Originally posted by deevergoteYou have to think outside the box to get IN the box!
Here is what you do,
Look at the car.
Is the steering wheel straight?
Are there any leaks?
Are there any loose panels?
Are there any abnormal noises after said incident?
If NO to all those then you are fine, I've bottomed out many times, And if you are not leaking anything and your wheel is straight and your wheels are not bent then you are fine.
there's also a crossmember underthere, so you could just be hitting that. But the first thing I would check is the Downpipe and oilpan for damages.
My front side tow hooks and front center jack point (also center tow hook) usually hit before anything else.....check them for freshly scraped metal because that's probably what hit. And you'd have to hit those points pretty hard to damage something, although bottoming out at all is never the best thing!My Member's Ride Thread
my co=worker had an 92 cb and he bottomed out on a man hole, and hit the trans, blew the air bag and hit a wall cuz of the air, bag, but as every one else has posted, check underneath, and inspect, my cb9 is lowered, and i also ahved bottomed out but usually its either the oil pan or the cross member for me
i bash the shit out of my undercarriage... passengers always flip OH MY GOD IS YOUR CAR OK!?! ahhhh whatever im used to it... its usually the crossmember that hits first, which really doesnt get hurt...
