...in the transmission area
So, I just replaced my clutch and flywheel for an exedy OE replacement, and a Fidanza 8 lbs flywheel.
I got everything back together, went to start it, and it did not start right away. After several crankings later it started. However, there is a VERY loud and high pitched squeal coming from the transmission area, and some kind of smoke like.
I think it is either the starter, or the throwout bearing causing the noise.
I hope it is the starter. I am going to take that off tomorrow.
