drivers side window
    drivers side window
    my window is not lined up properly anymore, when i roll up the window, the back of the window sticks out and comes out of the door, not falling out but sticks out, what do i do to fix it up? if u dont know i mean i can take a pic of it
    Cause im da Honda Man!! yadadameen
    R.I.P. 92 4dr lx
    Newborn- 05 v6 coupe
    U have to replace the window track rubber (did mine last week)
    PURCHASED NOVEMBER 1991. THAT'S RIGHT, I'M THE ONE AND ONLY OWNER. BEAT THAT!
      were can i get that?? do i have to go to the dealer or would pepboys carry it??
      My Ride
        can we get some pics or a diy on it?
          yes how i go about doing that, this window thing is getting annoying, when i have the window up, i still hear air rushing in
          R.I.P. 92 4dr lx
            i got the same issue. i hate it.
            diy would rox0r. its the window track frame though, a common 4th gen issue.
            '93 Bordeaux Red Pearl LX 5MT
            Prev CBs:
            -'93 BRP LX 4AT
            -'92 AGP LX 5MT
            -'93 AGP EX 4AT
            10yrs after my first cb, I'm still driving one!
              Your rubber window run channel is bad.
              I wrote something up on how to replace them, but I forget which section it was in. They are like $65 from Honda new.
                so if the window track frame is replaced, is that all that needs to be fixed, nothing else?
                R.I.P. 92 4dr lx
                  yeah, that should fix the problem. exact same things happened to both my driver and passenger side window, and when i replaced them they worked perfectly fine.
                  still work fine 10 months after if i had them fixed
                    I had the same problem on both windows driver and passenger side it was so bad I window fell off track.. What I did was take the panel off and get in there where u can see the window inside the door, and loosen the tabs that hold the window in place and re align the window, but takin off the tabs and puttin it on track. To see if you did it right simulate the way the window will work by movin the window up and down with your hands and if it looks right re connect it to the tabs and your set.
                      Does the window track frame also have o do with my window rattling when i close it with the window open?
                        does the rubber track just peel off?? and the new just snaps on?? i noticed the rubber track by the side mirror starts to crunch up as i roll up the window and is causing the other side of the window to stick out out of the track
                        R.I.P. 92 4dr lx
                          ok here it goes.
                          there is nothing wrong with the rubber track. there is noting whatever is wroing is with the contral arm. that thing where the widow sits.
                            Sounds like you bent the arms on the regulator...same thing that happened to mine...
                            I *still* can't figure out how the hell you get the regulator out of there with the shaft for the handle... :\
                              92accordlx, is that little black circle thing missing in the top right corner if your looking at it from the outside?
