no compression cylinder 3!
    ok so i have an H22 and i lost compression in cylinder 3. all the other have 210. i also seem to be having electrical problems like my resistor box readings were to high (20.6). also my distributor coil burnt out, out of no where. so my question is can these problems be related, like is there a way the electrical problem could be causing the 0 compression or does it have to be piston or valve related for 0 compression to happen? example could an electrical problem or vtec problem cause a valve to get stuck open? any thoughts, come on this will determine if the car lives or dies! thanks.
    BB6 2001 Prelude SH
    Originally posted by Makaveli2k
    Don't be a sissy. Pull out, spit on the tip like they do in the porno's and get back in there.
    =p
    most likely a piston blew. idk where your electrical problems came from tho.
    miss my turbo cb7
      did you leak test it too?...Check your fuel/spark systems over, possible shorting/arcing somewhere.
        well when i got the car started it was very rough and wouldnt stay running, the exhaust smelt like fuel and the plugs fouled very quickly.
        BB6 2001 Prelude SH
        =p
          your spraying to much fuel. needs a tune.
          miss my turbo cb7
            well even if that were true, it wouldnt cause the 0 compression, right?
            BB6 2001 Prelude SH
            =p
              i could. i mean if your a/f is like 9 or 8ish. i could be to hot for the piston rings or pistons. are the spark plugs soaked?
              miss my turbo cb7
                no just black
                BB6 2001 Prelude SH
                =p
                  leak down test FTW lol
                  93 Accord LX Sedan (sold)
                    well u know when u get a free min. "hint" "hint" since i have no idea how to do that. i think if i get my loan approved im getting a new car. BB6 FTMFW AC FTMFW!
                    BB6 2001 Prelude SH
                    =p
                      put Cyl 3 at TDC, screw in the leak down tester into the spark plug hole and hook shop air to it.
                      if you here/feel air from:
                      PCV port = Rings
                      throttle body = intake valve stuck open/bent/burnt etc.
                      out the exhasut = Exhaust valve ^^^
                      Bubbles in the coolant = head gasket.
                      I was also taught that if you do a wet compression test (tsp of oil in the cylinder prior to the test) and it jumps up alot, that the rings are likely a problem.
                      Just bring that car to N. GA and i will trade you even steven.
                        im sure you would. lol.
                        dag man. my inspirational car is down. wtf? hope you get it right again man.
