What causes oil to come out the exhaust?
shooting oil
Lol...its deff. shooting oil out the exhaust as stated above...i just want to check to find out what exactly the issue is...also it leaks oil anyway from somewhere in the lower timing chain cover area so its hard to tell exactly how much is spraying out the exhaustOriginally posted by johnl View PostLook for oil coming out of the exhaust...
Keep an eye on your oil level. Using a thicker grade oil may help to some degree.
do a wet and dry compression test! do a dry test first! and then do a wet test! on the wet test add about a tbs or 2 in the cylinder you are testing, if the compression #'s go up from say dry= 120psi to wet= 190. that is just an example there has to be at least a 30+psi change aprox for the rings to be bad. if there is only like say a 5-10 psi change it would be your valve guide seals!Originally posted by southsidecb7z View PostIs there any way to test for any of this?...i mean the car runs fine i just noticed it spraying oil last night.
hope that helps
some cars have wings cuz they look cool.
some cars have wings cuz they increase efficiency.
some cars have wings to keep them from taking flight.
f1 fan
thanks mane, sounds a bit complicated but ill try, you mean add a tbs of water right? It is the stock engine with 250,000 + but i still highly doubt its the rings...i think a head job would do the trick and while im at it fix the damn oil leak!Originally posted by sleepycb7 View Postdo a wet and dry compression test! do a dry test first! and then do a wet test! on the wet test add about a tbs or 2 in the cylinder you are testing, if the compression #'s go up from say dry= 120psi to wet= 190. that is just an example there has to be at least a 30+psi change aprox for the rings to be bad. if there is only like say a 5-10 psi change it would be your valve guide seals!
hope that helps
hope that helps
Do this and you will save alot of dinking around trying to solve the problem.
Oil. Never put water in your engine.Originally posted by southsidecb7z View Postthanks mane, sounds a bit complicated but ill try, you mean add a tbs of water right? It is the stock engine with 250,000 + but i still highly doubt its the rings...i think a head job would do the trick and while im at it fix the damn oil leak!Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
Seems strange that it's blowing oil out the back......usually any oil will burn off before it reaches the end and you'll have blueish smoke. Are you sure it's blowing oil and not dirty water or fuel?
If it IS blowing OIL, then you have a very fast leak for it to be enough quantity to not get burned off in the exhaust system.....
dry/wet compression test should tell you for sure though!My Member's Ride Thread
