Well ive been lookin at alot of "Kits" but they usually only have either the tming belt water pump and those seals.. sometimes the balance shaft belt. but im tring to get a good size list of what ima need to pick up from honda to rebuild this engine.
Ive torn it completely apart and am ready for the assembly.
any parts u can think of will help
So far..
Upper:
VC gasket, Tube Seals and Dizzy O-Ring, Cam Seal, Valve Stem Seals, Thermostat, Headgasket, Plenum gasket
Lower & T-Belt:
Crank seal, Rear main, Timing Belt, Balance Shaft Belt, Oil Pan gasket, Waterpump, Upper and lower T-Belt cover w/ Seals
Misc:
Plenty of Hoses and FIPG(seals)
Rod Bearings
Pistons and Rings
Water Pump
Alternator
So far..
Upper:
Lower & T-Belt:
Misc:
Rod Bearings
Pistons and Rings
Water Pump
Alternator
