I hate electrical problems...part 9,000,001
    So yet again another damn electrical problem. So after my wire re-wire tuck, I put everything back in order, and yes in the correct order, assembled the body parts properly.
    I tried to start the car and nothing. It took about 8 tries and it finally fired up.
    So for the next few days after, I ended up pulling out my exhaust since I will be fixing my possible exhaust leak. I removed my exhaust and raised it , then dropped it down.
    Long story short, when I tried to start the car, it wouldnt crank. I also noticed that my battery, check engine, and oil lights were dim, while the rest of the indicator lights remained as normal, bright.
    Furthermore, I do hear my main relay clicking, and I got my starter tested and it passed. My battery tested at a 12.25 with everything off. Alternator problem? Highly doubt it.
    I was thinking it could be a loose ground but I rechecked ALL my wiring, especially the wires I tucked.
    Anyone experience this problem?
    What are the symptoms of a bad ignition switch? I dont even get a crank.
    Thanks for the help guys, in advance.
    Follow me on IG: @jdm_inspired
    93 'til infinity
    Bad ignition switch:
    - Makes car die
    - Unable to start
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      It doesn't sound like a loose ground, Rather a Poor ground.
      Check the resistance between the main ground wires and the body - high resistance will indicate a poor connection
      My 5.7 LS1 Holden Ute
        battery needs to be at 12.45 and above.
          To start a car? I thought it had to be above 11.xx?
          93 'til infinity
            ticking is it from the relay?
            i just got a call from my dad with the same issue. he says as soon as he closes the door, he will get ticking noises coming from the front seat. the car won't start....
            he had to remove a fuse and jump start the car to move it. but as soon as he stops and turn it off, the car won't start again.
            i will go and check it out soon, let you know if i find something.
              sounds like you have stray voltage or a loose ground
              ...adjust accordingly
                Bleh, back to square one.
                AHHH the agony.
                93 'til infinity
                  the main ground line on your engine harness. is not properly grounded.
                    I'll check it out. Thanks Jed.
                    93 'til infinity
                      that is def. NOT true.
                      A car will start with 10volts all day long, its not recommended but it will. My optima battery will go down to 11.5 after many days of not being run in the winter. It starts just fine.
                      90 accord EX automatic F22A4 232,500
                      DIY ram intake
                      0gauge/4gauge BIG 3
                      stock alt rewound to 120amps
                      optima orange top 830cca 1030ca
                      fully synthetic valvoline "Max Life" 5w30
                      Other rides:
                      2004 Jeep Liberty v6
                      2001 Honda civic ex coupe 1.7 vtec
                        well i found out what the problem was. the problem with mine was that the seat belt motors were bad for some reason. after turning off the car, they would drain the battery... all i did is charge the battery and remove the fuse for the radio/seat belt motors.... after 2 days the car starts fine.
                        now i have to find out why do the motors still work after the car is off.
                          Update:
                          Still working on putting my car back together. Wow its been over a month now. I tried to crank and still the same symptoms.
                          It's not completely together but I am assuming its a ground.
                          Will update again within the next couple of days.
                          93 'til infinity
                            have you confirmed power at the ecu?
                            member ride thread
                            DIVULGE MOTORSPORTS
                              I tried searching.
                              Is there a difference between wiring harnesses?
                              I mean can I use a 92 LX engine harness for a 93 EX?
                              This headache is killing me but I think getting a completely brand new harness will cut my headache in half.
                              EDIT: I know MT and AT matters. It's MT by the way.
                              93 'til infinity
