So for a while now my car has been having a bad idle. I replaced the rear mount with a new one over the summer and now the idle seems to be just as bad. I originally thought it was the injectors, but after replacing those theres no change. In fact, today my car died twice before i finally decided to just start it up, gun it and try to get it to idle. The cars fine when its moving. Today was the first time that it started up and then died. What do you guys think this is? My only idea is the EGR valve. I dunno if it matters, but theres a hole in the exhaust, somewhere around the cat. Thanks for the help guys
Idle problems, need help!!!
hmm.. a rough idle is one of the hardest things to diagnose.
could be electrical. maybe your wires are going, maybe your cap/rotor are going, maybe your spark plugs are going.
could be just your throttle cable is a loose and needs to be tightened. Maybe there's a sensor thats not completley connected. injectors, but you said you already did that. fuel pump, fuel lines.
the exaust shouldnt affect it at all.
again a rough idle is the hardest thing to figure out, good luck..
Have the Timing Checked.1991 Honda Accord Ex
Pics of the beast!
::::198.4 WHP and 146.6 WTQ Currently weighing in at 2700lbs...best time: 14.8@92mph::::
2003 BMW 330I Sport.....Daily Hustler....
Road Race #1
Totoro Squad #2
