knocking
    knocking
    i think i have a lifter knocking especaly when i warm up my car. how can i repair it what should i get and where can i get instructions how to change it. cause i work on my car 90 present of the time if i know how to do it.
    P.NO president of mixed breeded family car club.
    is it more like ticking or heavier metal on metal sound?
    PSN ID's:Tidashoni
    1992 Accord EX Coupe
    My FS Thread
    Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
      what kind of engine? because f22's dont have lifters.
      I <3 G60.
        oh i didnt kno we didnt have lifters yea i have a f22a1 it sounds like ticking its not to loud but i can hear it when im inside tha car. so what would it b.
          what kind of oil are you using?
            probably ned a valve adjustment
            I <3 G60.
              You want to hope the valve clearances need adjusting, other possibities are not so nice.
              It's a worry if the noise doesn't occur when the oil is cold (and thicker) but does when the oil is hot (and thinner). Could possibly be the start of a big end bearing on the way out (then it might not be). Have a compentant mechanic listen to it.
              Regards from Oz,
              John.
                A little ticking means the valve lash is off
                  i use 20 50 oil. yea im not sure if it makes tha ticking when the oil is hot. but imma check it out rite on yall.
                    20w50? that is way too thick. Why are you using such heavy oil?
                      probably to help slow the leaks.
                      I <3 G60.
                        maybe to help lessen knocking noises...?
                        Regards from Oz,
                        John.
                          It works!
                            i use the 2050 cause high milage and that the way i drive is high reving and fast most 2050 tells u y u sould use it depends how u drive and it has the discripsion that fits tha way i drive.
                              i been using Quaker high milage , and asked the guy that isnt synthetic better for my car and he told me no its not . thick isnt better for a older car, nd i could of sworn syntheic is better
                              but i get the same sound from my motor when the cars warming up/ and while driving its not extremely loud .. you have to guess its what 17 years of a engine being used and abused ? i think its a honda thing
                              Check Out My Work In Progess . . . . .
