I got a 91 Accord w/ H22a swap and manual tranny. The tranny worked fine when I had my original F22 motor. After the swap that's when the problem started. The first and biggest problem is that I can't shift. I have changed the master and slave cylinders and tried to adjust the shifter cables. Still nothing. Also the car makes this horrible sound like there's something loose inside, around the release bearing/clutch area. The first time that I dropped the tranny I replaced the release bearing and made sure that the release fork is not bent. Today I dropped the tranny again and this time I took apart the clutch thinking there might be something loose inside. The clutch, pressure plate, and flywheel seems fine. They do not look worn out at all. Now my question is, are the springs on the clutch plate supposed to be free playing?
If anybody can point me in the right direction it will be greatly appreciated. Thanks in advance!
Now that is funny.
