Just as title states got a code 4 which is crank position sensor. I searched the forums and no postings on code 4 so any ideas?
CEL 4 After H23 Swap
running H23 dizy casing with f22 internals to keep my internal coil harness. but I think thats the problem. Im not burning the fuel fully either exh mani started to glow when it ends up starting and still have a miss here and there. Im going to swap back to h23 internals and convert to external coil.Jeff
can be the actual, dizzy, or its out of time. Does it kind of crank long when you go to start it? Thats a indication right there you should recheck the timing.Previous cb7members ride thread
86 Nissan d21 in the workshttp://www.cb7tuner.com/vbb/showthread.php?t=155292
TSM Garage: Honda/Acura, VW/Audi, and Subaru performance and maintenance work.
Contact:Ben Cell: (302) 898-1840
im running the origional 90 wiring harness so it was an internal no etra plugs. Going to swap to h23 internals add my msd sci box and blaster coil been sitting around for years just havent used it lol. now i have a reason to wire it up.
when #1 is at tdc the rotor is pointing to #1 on the cap
i think its ignition, didnt have spark when i first tried to start after the swap and now when i try to crank ill get a hit here and there run for a sec or 2 then cut off and when it finally starts and idles CEL is on as soon as it starts running. and thats for crank position sensor. but not when it runs for a sec or 2 no celJeff
so the light comes on and goes off? If thats the case then yea i would swap out the dizzy internals or wire up your other coil and ign setup. But checking timing isn't with the dizzy, Even if thats right on (runs on the exhaust cam) the intake cam can be off a tooth and that will do it, happened to me before. Just pull off the valve cover to look at the marks on the cam gears to make sure its in time.Previous cb7members ride thread
starts fine idles good but went to test drive CEL again and felt like it had no power. Checked it 4 again so adjusted the dizy a little startd it and no CEL. went down the street had power which was good then got a CEL again checked it 4 and a new one now 23 knock sensor but there was no lack in power after the light came on.Jeff
i swapped back the h23 internals they were all brand new, and getting the same code as i did with the f22 internals but not instantly at start up only when i drive.Last edited by 90fourdoor; 02-21-2009, 09:58 PM.Jeff
i would just get another complete h23 dizzy, that hasn't been messed with, no offense to you but who knows what you did. And actually thinking about it, I don't think you can even take out the crank sensor, only like the ignitor, coil etc. And make sure the knock sensor is wired up right or you don't have a loose connection. If that doesn't straighten it out, CHECK YOUR TIMINGPrevious cb7members ride thread
Originally posted by 90fourdoor View Postok so I went and did the timing belt job over again and Im all ligned up and tight. Starts up runs fine no Cel until I drive down the street a little ways and I get 4 n 23 crank position and knock sensor at the same time. any ideas Im confused
Theres obviously a fault in the CKP sensor circuit, So swap the dizzy with a known good one and see what happens.
My 5.7 LS1 Holden Ute
