Brake Problem
    Brake Problem
    MY FRIEND ASK ME TO HAVE A LOOK AT HIS CB7 TODAY HES GOT A BRAKING PROBLEM HE CANNOT SEEMS TO GET NO BRAKES AT ALL HE HAS TO USE THE HAND BRAKE IN MOST CASES TO STOP ..NOW IVE STARTED WITH BOOSTER WHICH IVE CAHNGED AND STILL NO BRAKES..... IVE PUMPED UP THE PEDAL THE WHICH GOES ALL THE WAY TO THE FLOOR (SCARY) NO BRAKES !!!!!!!!! I TOOK IT OUT FOR A TEST DRIVE ANY AND STILL NO BRAKES !!!!!!!!!!!!! I'LL TRY BLED IT TOMORROW..... IN THE MEAN TIME ANY SUGGESTIONS ........
    '' we racing or you just blowing smoke ?''
    OK THANKS FIZZ LETS SEE WATT HAPPENDS TOMORROW SHALL WE
    DINNER ........IS SERVED
      caps lock stuck?
        http://www.cb7tuner.com/vbb/showthre...threadid=12781
          HMMM... THATS PROBLY DUE TO THE CAR SITTING FO A LONG TIME IN THE CIOLD AS HE IS AWAY IN AFRICA ....(SIGH) THANKS FOR TJHE REPLY YOU GUYS ARE JUST SUPER DOOPER ....
            OK AND ANOTHER THING IVE DISCOVERED ,I PRESS THE PEDAL WHILE THE ENGINE IS RUNNING AND THE REVS DROP DOWN TO 4,000 RPM AS IF THER ENGINE WOULD STALL AND SLOWLY COME UP TO NORMAL RPM IS THE NORMAL ?
            H22A SWAP ........
            ALSO IN H22 SWAP WHEN I CHANGE FROM PARK TO REVERSE OR DIVE THE RPM DROPS AND THEN SLOWLY CLIMBS BACK TO NORMAL
