MY FRIEND ASK ME TO HAVE A LOOK AT HIS CB7 TODAY HES GOT A BRAKING PROBLEM HE CANNOT SEEMS TO GET NO BRAKES AT ALL HE HAS TO USE THE HAND BRAKE IN MOST CASES TO STOP ..NOW IVE STARTED WITH BOOSTER WHICH IVE CAHNGED AND STILL NO BRAKES..... IVE PUMPED UP THE PEDAL THE WHICH GOES ALL THE WAY TO THE FLOOR (SCARY) NO BRAKES !!!!!!!!! I TOOK IT OUT FOR A TEST DRIVE ANY AND STILL NO BRAKES !!!!!!!!!!!!! I'LL TRY BLED IT TOMORROW..... IN THE MEAN TIME ANY SUGGESTIONS ........
Brake Problem
OK AND ANOTHER THING IVE DISCOVERED ,I PRESS THE PEDAL WHILE THE ENGINE IS RUNNING AND THE REVS DROP DOWN TO 4,000 RPM AS IF THER ENGINE WOULD STALL AND SLOWLY COME UP TO NORMAL RPM IS THE NORMAL ?
H22A SWAP ........
ALSO IN H22 SWAP WHEN I CHANGE FROM PARK TO REVERSE OR DIVE THE RPM DROPS AND THEN SLOWLY CLIMBS BACK TO NORMAL
'' we racing or you just blowing smoke ?''
