I was just woundering what the oil temp should be when completly warmed up and what the max temp is. Thanks guys!!
Oil temp??
Oil temp??
http://www.cb7tuner.com/vbb/showthread.php?t=91030 <--MY RIDE!
http://www.cb7tuner.com/vbb/showthread.php?t=140230 <--MY ongoing ENGINE BUILD!..Tags: None
Anyone?????
well when it warms up and running around the city/idling it reads 1/3 the way up, mechanic on hondatech told me his runs at the same everyday all day. I noticed when i get onto the highway it works alot less than at idle so the temp almost reads cold (not quite but well at the bottom) hope that helps.
i belive your talking about water temp, im talking about OIL temp, i have an oil temp gauge. it just seems like its really hot when im on the hwy just woundering what the max temp would be?? thanks
no one??
it gets up around 250ish.
You should not see much past 210 F max. If you're hitting 250 F, that is definitely too much.
I would first check that the gauge is accurate, compare the reading to a known temp substance or confirm with another gauge. If it is accurate, then definitely stop driving that engine and get the problem resolved.
Check if you're coolant system is working properly. If so, then it is probably something very wrong with engine internals. Also check your ignition timing is set properly, I would check all spark plug conditions as well to get an indication per cylinder.
thanks alot! thats the answer i was looking for! i will check all that and then some!
Hondafan81 basically nailed it. Most oils function the best around 185-200 degrees. Anything over or under that will hinder performance. This is why some people have problems with oil coolers "overcooling" oil to where they dont reach the proper operating temp.
im running castrol syntec 10w 30.Originally posted by wed3k View Postwhat oil are you running?
At least your running a good oil. Have you checked what HondaFan81 wanted you too? I'm interested to figure out what this is.Originally posted by motobmx105 View Postim running castrol syntec 10w 30.
"The Turtle"
DD/Trail Rig/Mud Bug
i havnt checked anything yet i just got off work i will run down the list of stuff to check today. and let everyone know how it goes. another question i had is how much oil on average do the f22s burn? its got about 140,000 miles.... anyone know?Originally posted by wed3k View Postnot enough clearances can usually lead to higher oil temps. im wondering if 250 is normal for a honda though?
