hey guys, as some of you might know i jut recently got an h22 swapped in my accord and had a couple of problemsbut solved most of them( thanx to this site and many people, and now ran into another problem, now the alternator dont want to charge? any suggestions, its a 91 accord with a jdm h22 with auto lsd. we checked everything but it seems fine, we cant come up with a solution, any help appreciated.... thanx
alternator not charging?
Here a few things to check.
#1 Make sure Fuse 32 (it should be 100Amp) is not blown.
#2 Make sure the White/ Green wire coming out of the alternator is not grounded out and that it goes to Pin A16 in the ECU
#3 Make sure that the White / Red wire coming out of the alternator is not grounded out and that it goes to pin D9 in the ECU
#4 Check the Green/Black wire coming out of the under hood fuse box and make sure that I goes to pin D10 in the ECU
IT IS WHAT IT IS
Originally posted by dee88 View PostIs the alt getting power? Check the connections, take the alt to autozone and have them test it.
91 ex coupe-daily
91 2.0si (cb6)original RHD-project
R.I.P sedan.... will be missed
91 ex coupe-daily
How are you checking for charge? If you use a voltmeter on the battery with the car it should be about 14 volts. The belt tension should be at most a 1/2" of play. You can also check the alt circuit continuity(disconnect battery) with a vm from the plug to the battery cable terminal. Thats the easiet way to find a break or short in the wiring. Otherwise you have another bad alternator.
Originally posted by Fake Thug View PostHow are you checking for charge? If you use a voltmeter on the battery with the car it should be about 14 volts. The belt tension should be at most a 1/2" of play. You can also check the alt circuit continuity(disconnect battery) with a vm from the plug to the battery cable terminal. Thats the easiet way to find a break or short in the wiring. Otherwise you have another bad alternator.
91 ex coupe-daily
Originally posted by vh22accord View Posthave you tried checking for voltage directly out of the alternator? also check your grounds by your battery there should be two make sure the one on the fender is tight.
91 ex coupe-daily
I changed up to 3 alternators on one car at the same time, all 3 alternators were faulty. Where are you buying these alternators from and in what condition. Go get one from Honda and at least you'll know its good. The rebuilt ones suck, (most of the time). Usually the voltage regulator inside fucked. Get a volt meter and check the the green plug that goes to the alternator. Turn the key on, engine off and see if your getting power, try it with the engine on as well. That will save you trouble of checking the ecu pins like vh22accord suggested. Good luck.
Originally posted by CBAccordA4 View PostI changed up to 3 alternators on one car at the same time, all 3 alternators were faulty. Where are you buying these alternators from and in what condition. Go get one from Honda and at least you'll know its good. The rebuilt ones suck, (most of the time). Usually the voltage regulator inside fucked. Get a volt meter and check the the green plug that goes to the alternator. Turn the key on, engine off and see if your getting power, try it with the engine on as well. That will save you trouble of checking the ecu pins like vh22accord suggested. Good luck.
91 ex coupe-daily
Originally posted by 91_accord_coupe View Postthanx for the suggestions, for some reason everything checks out perfect but still no charge, and the alternator got it from autozone and had the test it because the first one was faulty.....so idk
