90 accord DX left rear window goes down but not up
    Getting my sons first car on the road. Now we're a 2 CB7 family. The left rear window goes down but not up. Anybody know how to test the switch, motor, & regulator to see which it is that's bad?
    Thanks
    Ironhead
    LIVE FREE OR DIE
    So it's a DX? DX's don't have power windows.
    Both the master switch and the door switch don't make it go up? Take off the door panel and apply direct power to the motor, swap polarity to change direction. The regulator could also be broken.
    1992 Accord Wagon (RETIRED)
      99 percent it's a DX. Neither switch makes it go up. Is there a test for the switch? Have found a few new motor/regulator units on Ebay for $43 with a 1 year warranty. Want to make sure it's not something else before spending the $$$$ first. It's his first car and I'm sure he would rather spend his $$$ on look good stuff instead of parts that are not bad.
      Thanks
      Ironhead
      LIVE FREE OR DIE
        probably off the track?
          If there is a switch its sounds like power windows, and therefore should be at least an LX--stateside. Otherwise, you'd be talking about windows crank handles.
          '92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
          EX Lip & Alpine OEM single CD Player. No more useless pocket!
            I appreciate the info but regardless of whether it's a dx, lx or xxx it has power windows. I have taken out the motor/regulator assembly and pushed the glass back up to close the hole for now.
            Again I ask. Is there anything else I should check and how to see if it's something besides the motor/reg display?
            LIVE FREE OR DIE
              OK you guys are right and I was wrong. It is an EX. Is there any way to test the switches? also is there anything between the switch and the motor/regulator I need to check?
              Thanks
              Ironhead
              LIVE FREE OR DIE
                What switch are you using to wind up the windows?? The rear switches or the front master switch or both?? Even if the regulator was bad, it would at least try to go back up slightly is it goes off track. Those switches are pretty small and cheap, worth picking up at the junkyard to test it out. Also if you open the switch, if its bad theres usually a burnt contact
                FOR SALE on cb7tuner only for now. Want it in the right hands
                Pm meX
                I do swaps in NYC/LI area: Hit me up for a quote.
                MY WHIP
                H22A Swap
                I'm 'THE STIG'
                  Using both switches. Nothing happens on the up side, not even a sound. Leaving for FL today for a funeral but will begin testing this weekend.
                  Thanks for all the advice and info.
                  Ironhead
                  LIVE FREE OR DIE
                    i had the same problem it sounds like the master switch for the windows which is that big switch on the driver door that controls all the windows. when that goes bad the other switchs act up as well but they may not be the problem they feed off the master switch. should be about $40 at the local junk yard
