1990 2Door EX-R 5Speed Q?
    Engine will not go over 3500rpm? Is there and easy fix for this? I have been told that all it is, is a TPS Sensor? Is this so? If so is it and easy fix?
    Thank You Much!
    Josh?
    http://www.cb7tuner.com/vbb/showthread.php?t=121793
    its right on the backside of the throttle body, its a quick fix but can be tight fit for unscrewing it
    Originally posted by zack_odom
    Yummmmm. I'm going to go eat some Buddy Club sauce with my Mugen Spoon.
      And you can't unscrew the stock TPS from the throttle body without modifying the stock hardware. I like to use a dremel with a cutoff wheel to cut a well-centered slot in the smooth screw head. Then you can use a flat bladed screwdriver to remove the stock screws. TAS sells replacement sensors with new hardware. Any 90+ Honda throttle body will have one you can use.
      You can test it's resistance and range with a voltmeter to see if it's broken, and you won't even have to remove it.
      The screws are M5x0.8 at the hardware store, and you may need a new gasket.
      If it's too hard to do this with the TB in the car, I'd consider removing the Throttle body, be careful with the old gasket(s)
      PM me and get it done right!
        That my friend is some wicked advice, with some very detailed information! Thank you very much! I will be on my way to get this car tommorow and i will make a profile for it! Bzzzzump for you kind sir!
          Thanks for the props and Good Luck!
