car wont start need help please.
    car wont start,
    just sits there and cranks, wont turn over, idk what it is...
    cranks hard.... if thats a good description
    Originally posted by 91accorddxbuds View Post
    car wont start,
    well.... your battery is strong.
    check for spark and fuel.
    check your main relay.
      check your battery to see if it's clean and in working order, your spark plugs, check the starter, alternator, check your fuses, see if you're getting fuel, pressure, check for loose connections I dunno man check check check..
        I'd lean towards main relay as well, and for future reference; if it cranks, it turns over, but won't fire. crank and turn over mean the same thing, it means the crankshaft and pistons are rotating, but there's no combustion to continue the process.
          ok well u no what i meant. it cranks hard, and fast so i dont think its the battery, .......... umm wheres my main reley,?
          and mite it be the starter? or would it not crank so much if so?
          its sitting at work i need to find a tow truck or something...........
            not the battery. not the starter.
            main relay is behind the dash, above your fuse panel.
              ok i thought of some more things.
              it dies like a minute after i was driving, (didnt get out of works parking lot)
              and it didnt smoke, or squeal just died.........
              the 4th spark plug looks old.... would that possible it?
                your symptoms are pointing closer to your igniter.
                  ok well what should i do for my first step, u guys all no best for it.....
                    did you check for spark and fuel yet?
                      yes sorry for late response
                      there IS fuel
                      and there is a spark
                      ............ stumped
                        it may be the ignighter u say, but how to no for sure?
                        i dont want to just buy one, then be stuck with it? they are expensive i am guessig
                          if you have good spark and proper fuel pressure then you should be able to fire your motor.
                          try starting it up again and see if it runs.
                          if it does and it dies again then you can pretty much bet that its an igniter or very fouled plugs.
                          when our igniters break they tend to stop working once they get hot.
                          its common to stall at weird times and start back up again after a few minutes when they begin to crap out. sometimes being able to drive as normal and sometimes stalling again soon after.
                          they arent cheap if you buy one new.
                          hit up the junkyard and see if you can find one there. most of the time a honda isnt in the yard for a blown igniter.
                          i dont condone any criminal activity, but junkyards can afford to "misplace" parts like this from time to time. along with MAP and knock sensors and the like.
                            hah yah im totally down for misplaceing""" a part lol
                            but yah then it cant be the ignighter, because i waited til the engine and everything was well cooled down, and tryed it multiple times, and it just cranks and cranks but no start, even after cooled....
                              it could still be your igniter. it could be so far gone that it wont start the car again.
                              always good to have a spare around anyway.
