Drove a while and now wont start
    OK so i drove my cb today for quite some time about 12 miles on the highway then alot of city driving and then back on the highway for 12 miles and alot more city driving... well i go home and get something i had to mail and went to start it and it wouldnt turn over.. now ive checked
    grounds
    tapped the solinoid
    pretty much everything i can think of
    well i had to leave so i put the key in the on position and tryed to pop start it... no go
    so i left it in the on position and put the ebrake on the jumped the wires on the starter and it fired up.. what do you guys think it is..
    btw ive searched and cant find this precise problem anywhere.
    ** BUY MY STUFF **
    grounds
    tapped the solinoid
    Did it start after a while? Is it hot there? If so, then it's your fuel pump relay
    what do you call 2 lebs in an accord?
    Organized Crime
      i replaced my main relay about a month ago
      ** BUY MY STUFF **
        If it was that, the starter should have at least cranked the motor. He had nothing...
        http://www.cb7tuner.com/vbb/showthre...=1#post1823428
        My Custom BB6 Dash Swap Thread
          I think its your ignition switch. Especially since it started once you jumped the starter. By doing that you bypassed the ignition switch.
          1990 CB7 - Almost Done - Delta 272, SRI, 2.25 catback, Bisi intake manifold gasket, A6 intake double stacked, H22 plenum, AEM cam gear, F23a block, F22a head, Wiseco K20 pistons, DSM 450cc injectors
          2004 Z33 - Brembo BBK, Nismo spoiler, Nismo lip, Nismo shift knob, AEM CAI
            check for CEL codes. I'm willing to bet you'll throw a 15 which is your igniter.
              pop start= roll start? check ur clutch switch
