Replace OEM lights
    Replace OEM lights
    Hello
    How do I replace the lights on the CB?
    My left headlamp went out and I need to replace it. Is there a How-to somewhere? I searched and all I could find was replacing the OEM with HIDs.
    Thanks
    just go behind the headlight, unlock the blub and pull out th bulb..disconnect the bulb.
    replace bulb...and lock. job is done
      yeah its pretty easy if you just look.....
        I would suggest a Haynes manual to you my friend. It can help you in so many ways
        FOR SALE on cb7tuner only for now. Want it in the right hands
        Pm meX
        I do swaps in NYC/LI area: Hit me up for a quote.
        MY WHIP
        H22A Swap
        I'm 'THE STIG'
          i need to replace one..... i can't seem to unlock that gray circle thingy.... is it squeeze and turn or what? thing doesn't budge!
          '93 LX Accord Anniversary Auto
          66K Miles (yes, only that much) and no rust!
            It just turns. No trick to it.
            Sometimes it's a little tough to get off because it probably hasn't been moved in years. But, just use some elbow grease.
              Give it a good yank after you've spun the collar. If the battery proves to be in the way, remove it
              life is good.
                wooooooooooooooooooooow, what a pita......
                i couldn't budge the wheel so gave it a few light taps with a flathead screwdriver.... came off, finally....
                had to remove the screw for the wiper fluid resevoir and slid it over a bit so i had more room to move around...
                luckily, the right (batt side) light is ok.... i hope i sell this car before i have to deal with this again....
