i have a cb7 with a h22a in doing a oil change this weeked coming up i do used the car alot put about 300 to 500 a week stop and go as a pizza deliver drive as part time job what is the best out there? ( i used my other honda is pennzoil and i add a lucas bottle) second ? is i will be replacing the tranny in two week in going with a f22 tranny what will be the best gear oil i should used? thank u for u time
best oil to use
use either of the synthetics...listed from lowest to highest priced:
valvoline synthetic
castrol synthetic
royal purple
amsoil
torco
do not use conventional oils as synthetics are cheaper in the long run and protect MUCH better. Mobile 1 synthetic is supposedly not a real synthetic
don't know about their "new" stuff.
when using synthetics, change your oil filter every 5000 miles, buy 1quart of the synthetic as you'll need to top it off a little...then a complete d&f around 15,000.
I've just begun an oil test with my car using castrol syntec to see what my oil change intervals REALLY should be.__
__
i use 10w40 castrol gtx since there was some in the trunk when i bought the car
... i have to add a qt of oil every 600-1000 miles
Blake.
1994 Accord Part out!
Me and my step dad's 1991 Accord EX Coupe MRT
82 accord-rip, 94 geo-sold, 82 cavilier-rip,81 civic-rip,88 accord- rip, 88 legend- rip, 91 civic- sold,97 geo-sold, 92 accord- sold 94 accord- RIP, 1990 Camry- RIP
http://www.cb7tuner.com/vbb/showthread.php?t=55269
http://www.cb7tuner.com/vbb/showthread.php?t=55330
read those 2 carefully... plenty of info there.
Honda MTF, rough 1.5-2 quarts. Or 10W-30 motor oil. Also I personally dislike Mobil 1, to much valvetrain noise compared to Castrol GTX. I have used both Castrol Edge and Syntec, both are good oils in my opinions. I have never used Royal purple due to the fact it is said to be no better than say Mobil 1. I gonna use Ams Oil this next time around to see how good it is since is roughly the same price as the stuff I use now. Also as filter goes, I like to use the K&N filters. As far as intervals go 3-5k no more than that.Originally posted by sweet91accord View Postand the tranny gear oil ? with one i should used
pear_b: my guess is drain and flush but who knows.
That also brings me to something that could be helpful. If your engine has a lot of sludge, go get some kerosene and flush it out. I have never tried it but have heard from many mechanics it works.
Another thing concerning oil viscosity. If your motor has a lot of mile on it and is getting close to a rebuild. Switch to a higher weight, maybe a 20W-40 or in that range. The thicker oil will maintain higher oil pressure, since worn bearings and thinner oils causes quicker wear and low oil pressure.Last edited by 93F22A6; 09-28-2009, 09:46 PM.
"The Turtle"
DD/Trail Rig/Mud Bug
Do not put motor oil in your transmission. Use only Honda MTF, or GM Synchromesh (it's not the correct stuff, but it does seem to work very well...) Our transmissions do not take "gear oil". "Gear oil" will desroy a Honda manual transmission.
Do not EVER put additives in your engine or transmission oil.
As far as the "best" oil... honestly, for 99.9999% of the members of this site, any oil that lubricates properly is just fine. You won't see a significant difference in performance or reliability with expensive oil. Just get quality oil, and you'll be fine. Any of the well known name brands should suit your needs, as long as the weight is correct. Synthetics tend to find leaks faster... so if you have oil leaks, avoid synthetic oil. Or better yet, fix the leaks and then use synthetic.
leak + 240k mile piston ringsOriginally posted by CB7_ACCORD View PostGreat leak huh?
I used Mobile 1 5w30 all the time.
Blake.
