Hid Help
    Hid Help
    I just got my DDM tuning 35 watt slim ballast. kit I tried installing it and it wouldnt work, I tried different several connections and still no luck. I have the relay that powers it straight from the battery. If anyone can help or give a diagram of what way you plugged this in it would be extremely helpful. Thanks.
      take a pict of your set up preferably off the car.
      [COLOR="Magenta"]
        Im at work till 8. but when i get home ill take pics asap. Thanks
          I took some pictures. I have the wiring harness that has two connections. Then I have the connection where the stock bulb was. And 3 more connections on the kit. One of the connections come out where the bulb is. Heres the pics.
          http://www.flickr.com/photos/39534974@N03/
            http://www.ddmtuning.com/images/prod...ondary/265.jpg
            theres a pic of the kit
              I had to reverse the polarity for mine to work.
              wat?
                My question is what do these three connections go to? One goes where the stock bulb was and 2 go to the wiring harness. Im just confused on which ones. http://www.flickr.com/photos/39534974@N03/4009548541/
                and the two harness connections
                http://www.flickr.com/photos/39534974@N03/4009398893/
                  hid kit confuses me lol
                  usually ballasts have two wires coming out, one goes to bulb, and the other going to the stock harness.
                  The wiring going to your bulbs seems to split off into 3 other connections-- bulb, and two mystery ones.
                  Only thing i can think of is both of those extra connections plug into the other ballast.
                  or you possibly have bi xenon kit o.o
                  here's a good install
                  http://www.sharphid.com/installation...olvo%20S40.pdf
                    I had to do the same thing, the company had the (+) and (-) connections reversed on mine. Pull back the wiring conduit on the stock wiring harness and make sure the connections are correct.
                    Originally posted by 92dm
                    I was actually just being a smart ass, and not really contributing to this at all.
                    VOUCHES
                    Bought from: cb95spd
                      thats a plug and play kit. yes do check the + and - on the kits this is a common mistake. i had to do this on my neighbors civic hid PLUG and play kit.
                      [COLOR="Magenta"]
                        i had a couple friends who had the same problem with the polarity being reversed
                        Click Here To Check Out My Ride
                        http://www.cb7tuner.com/vbb/showthread.php?t=137030
