okay so im driving along and come to a stop light and al of a sudden my car revs up to 3000 rpm and then back down to about 1000 what the hell happend? it just keeps doing it over and over please help me i have to drive it in the morning.
1k-3k idle problem. help
http://www.cb7tuner.com/vbb/showthread.php?t=91030 <--MY RIDE!
http://www.cb7tuner.com/vbb/showthread.php?t=140230 <--MY ongoing ENGINE BUILD!..Tags: None
hmm ill try it. ive cleaned it once before but ill check it out
ill check it out
okay so its not the iacv... anyone else ??? i need helpOriginally posted by motobmx105 View Postill check it out
well its not avacuum leak that was the first thing i checked so idk what elseOriginally posted by champagneaccord View PostSounds like a vacuum leak.
change out your egr and clean out the ports on your intake manifold. go to honda and get 4-6 plugs depending on how many u have they are only like 0.35 cents a piece so ull walk out of honda with out spending more than 3$ and the procedure takes less than 2 hours at most. its very simple and easy to do. but change out your egr 1st. this is a chronic problem for some people. we swapped a jdm h22a in a friends cb7 and he still had the issue.
http://www.preludepower.com/forums/s...t=slide+hammer
report back to us after youve done these 2 things.Last edited by xkjnboix; 10-22-2009, 02:38 AM.
well i know my egr is bad cuz a little while ago my cel came on and its the egr valve and i already drilled and tapped the intake mani for easyer cleaning so ill clean them again and get a new egr valve today. thanks guys
just cleaned the egr ports and the egr valve. its still doin the same damn thing i guess i have to go spend $140 on new fuckin egr valve ugh i have a feeling that wont fix it.
does anyone else have any input on this? ive disconected the battery to see if it was the ecu or something and its still doing the idle thing
okay update ... got a new egr valve and swapped the iacv and nothing changed!!!!! WTF!!!!Originally posted by Brandoncb7 View PostWhy not just make something to block off the egr?
CB7_HULK SMASH!!!
