Recently i have had 2 problems, my horn doesnt work and my brake lights dont work. the running lights work fine it just the brake lights dont come on when i brake.. i dont know what it is, i looked for all the wires and nothing is lose. its ironic that my horn and my tail lights both dont work recently. any clues :/
Brake lights dont work!!!
Never put in a higher rated fuse. If the 20A blows, there's a short somewhere. Probably in the horn circuit. 20 amps is a lot of current. I would check if the one of the horns is shorted out, then check to see if a wire has frayed (or melted) and is shorthing to ground.Originally posted by Junior SmurffNevermind guys, google search works wonders!
would something happen if i just run with 30A for tonight? i disconnected the horn. how can the horns be shorted out, u mean inside the horn itself? the connector looks ok.Originally posted by 4GAccordH22 View PostNever put in a higher rated fuse. If the 20A blows, there's a short somewhere. Probably in the horn circuit. 20 amps is a lot of current. I would check if the one of the horns is shorted out, then check to see if a wire has frayed (or melted) and is shorthing to ground.Need CB7/H22/Turbo parts? i got them..check thread
If you're blowing 20A fuses, there is definitely a problem. You're better off with a blown 20A fuse in there than a 30A that works. The wires in the circuit were not designed to carry 30A and that amount of current can damage them. The fuses are there to protect the wiring in the car so that the fuse will blow before the wires are damaged. I would rather replace a fuse than an entire wiring harness!
When you disconnected the horns, does it still blow the 20A fuse? If so, it is probably a wiring issue. If you have a Helms manual, Helms Electrical Troubleshooting guide and/or a Chilton (or Haynes) guide, you have your best resources in hand. If you have none of these, I would recommend the Helms set. Expensive, but well worth it! If you can't afford that, at least get a Chilton or Haynes manual. Some of them have wiring diagrams that may help you with this issue and many others down the road.Originally posted by Junior SmurffNevermind guys, google search works wonders!
thank you, i went to the store and bought 20A fuse. i put it in and brake lights work perfect. Now the horn is disconnected, i went to use the horn and the fuse blew so its got to be a wiring issue with the horn..because the fuse is fine until i honk the horn..Originally posted by 4GAccordH22 View PostIf you're blowing 20A fuses, there is definitely a problem. You're better off with a blown 20A fuse in there than a 30A that works. The wires in the circuit were not designed to carry 30A and that amount of current can damage them. The fuses are there to protect the wiring in the car so that the fuse will blow before the wires are damaged. I would rather replace a fuse than an entire wiring harness!
edit: ok i managed to bring up the wiring diagram for the horn. do both horns have to be hooked up in order to work?Last edited by LeosCB7h22; 12-11-2009, 08:06 PM.Need CB7/H22/Turbo parts? i got them..check thread
did u go over any big holes that mad ur car hop almost.cause this same thing happend to me in my old cb and it turned out to be the ground in the wheel for the horn can loose and every time id hit the horn the ground would hit the posative and pop the fuse.try it never hurts to lookOriginally posted by LeosCB7h22 View Postat the steering wheel? that what i was thinking!.. what should i look for
in the steering wheel right? i am going to do that tomorow hopefully ill get it to workOriginally posted by 92smokeaccord View Postdid u go over any big holes that mad ur car hop almost.cause this same thing happend to me in my old cb and it turned out to be the ground in the wheel for the horn can loose and every time id hit the horn the ground would hit the posative and pop the fuse.try it never hurts to lookNeed CB7/H22/Turbo parts? i got them..check thread
where do the horn wires run thru? under the fender?? plz help
