i know that there was a thread on here about this before but i was wanting to know if anyone found out what it might be. i fill up my car and when i do i have a really bad gas smell but only when i crack the windows. i am going to check all of my evap lines in the engine bay but is there anything that i need to check from the tank if any one has had this problem please help its getting bad.
gas smell
When you check for the leak, check it running and look for a spray or tiny stream. I could barely smell fuel in my coupe a few months ago, but when I pulled over and popped the hood, the fuel supply line for my nitrous had started leaking at the solenoid. (Probably not your problem)
The reason I tell you is that even though I could barely smell it, it was easy to see with the car on and the fuel pumping under pressure, it was about an 1/16 inch diameter stream squirting up into the air. When I shut the car off, it leaked off pressure until it didn't show up anymore.
Good luck!
