I pulled out of the gas station after I got gas and hit vtec in first gear and the car just shut off at 7.5k. So I pulled it onto the side of the road. I tried to start it and it would just crank and crank but it wouldn't start OR sputter. I checked the plug wires and the fuel line. They were okay. and of course the battery was fine or it wouldn't be cranking. But then a guy stopped buy and sprayed starter fluid in the air filter and it started right away and ran until it ran all of that starting fluid through.
It's running a code 15 = Ignition Output signal
That's the only code it is running.
Do you guys know what I can do to get it off the side of the road without towing it?
How can I fix that?
How can I fix that?
